Hello guys. I just got a 944 1985-1/2 that I am using for track events primarily, has the cage, racing seats, harness, etc. Great car with a great body style. I have a few things wrong that I would like to fix:
1. Horn doen't work. Where is it? Need to test to ensure it is getting power
2. Backup lghts not working. All other tail lights do work. I think there is a backup light switch, but need to know the location so I can swap it
3. Smell of gasoline in garage. Filled up the tank and parked it in my garage. There is a noticeable smell of gas. Is it common or is it a charcoal canister replacement issue?
Thank you all in advance. I have done most of my previous posting in the 996 Forum.
Izzy
1. Left front - behind the mud splash guard.
2. Similar to the 996 the back switch is on the top right side of the transmission (more towards the center)
3. I assume no visible leaks. Checked the gas cap?
I would try to see if the smell is stronger towards the front (carbon tank) or the back (expansion tank).
Thank you Brother Loren! Will tinker with it tonight. There are no gas leaks, but did not check the gasket on the gas cap. Spend all afternoon yesterday replacing bulbs. Great car so far, will be on track in about 2 weeks.
My nephew had an '84 944. It had a noticeable smell of gas. A few days later his car went up in flames all by itself. He thought it might have been due to old fuel hoses. Given that your car is almost a quarter of a century old, you should check all your lines carefully for fuel leaks! Replacing anything the least bit questionable might be cheap insurance
Thanks Geoff. I had similar thoughts, so checked the lines first. They are all new SS ones, Pauer Tuning braided lines. Will double check for any install issues, but I didn't see any leaks (yet)
These are the bad boys:
http://www.pauertuning.com/fuel%20lines.htm
I am having the car detailed today at work, to do a good scrub, remove all the dead bugs and snakes, etc. It was a blast driving in, burning rubber on the first 3 gears is addictive.
Edited by Izzy
the line coming off #5 the carbon canister is short, so fumes come out right under the drivers seat. there was an old bulletin about adding a piece of hose to extend it back a bit further
