any one have advice for this , when i start at morning ( or car is cold ) the temperature is comming very slowly , maybe is water pump ?
Could be the thermostat that is stuck in the open position.
You say very slowly, need a better description. It can take more than 3 miles travel to get the engine up to temp! If the thermo was stuck open the engine would probably run on the cool side all the time. Try and tell us what yoyu mean by slowy?
It can take as long as 15 - 20 minutes to get the engine up to 190F. If your thermostat was stuck open, it would only add about 10 minutes to the process driving around town. Highway speed will increase the warmup time.
ma car is 2001 c4 , very slowly , mean's i need take 10-15 minutes to driving around town , the thermostat coming 190F~ it's normal ??
