Guys, I am contemplating buying these Xenon's to match with my factory Zenon low beams on my 1999 Carrera. Does it work and is it worthwhile?
They are currently on auction on eBay for 90 bucks. Type H7 from what I understand. Any issues ( high power requirement??)
YOU GOTTA HAVE THESE XENONS IF YOU OWN ONE OF THE GREAT PORSCHE 911 (996).
What makes these PREMIUM XENONS so unique is its ULTRA XENON GAS inside the ceramic-based tube, the glare my XENONS produces are one of a kind. They are not just much BRIGHTER than the stock and other brand bulbs; these XENONS are laboratory-proven to output CLOSEST light texture compare to PORSCHE factory XENON-Lowbeams.
Our PREMIUM XENON(Trademark) halogens bulbs are developed & engineered in Motron' Lab in Germany - the Hometown of Porsche. These PREMIUM XENONTM Halogens are the Closest performer EVER to the Porsche factory Xenon lights.
If you have the factory xenon lowbeam lamps, You can use my PREMIUM XENON Halogens as your Foglights & Highbeam to comply with your factory Xenon lights. So your foglight will not look "Yellowish".
These PREMIUM XENON halogens I'm offering are SIMPLY the BEST, They are made by XENON tm. I'm a PORSCHE fanatic, I've tried 8 different kind of bulbs prior these XENONS (PIAA super white $88, super plasma $140, plasma blue $137 & Solarix etc) and Nothing close to my Xenons as far as the performance and Xenon glare. My XENONS halogens IS the closest thing to the PORSCHE factory Xenon with fraction of the cost!
THESE PREMIUM XENONS ARE WORTH EVERY PENNY!! The installation is easy as 1-2-3, I can be able to provide your Xenon installations via e-mail. I'm using these Xenon on all my cars and I LOVE IT! Every customer was surprised upon the installation of these Xenons. THEY ARE THE CLOSEST THING TO THE FACTORY XENON and look even better; the light texture is BRIGHT, BEAUTIFUL & LUXURIOUS! FYI, the installation of the factory Xenon is impossible because there's is no self leveling device, and they will DEFINITELY cause a conflict your in-dash computer systems (A message of "CHECK YOUR LOW BEAM" will flash every time you turned on your headlights) The factory Xenon is $1200 ~ $2000. Ask your Porsche dealer and they will tell you it is not doable even if you pay the high price. SO ACT NOW! These Xenons will be the BEST $ you've ever spent on your PORSCHE!!
You will get the BRAND NEW In-The-Box XENONS. Don't miss this GREAT OPPORTUNITY!
We accept PAYPAL (Send Payment to Our PAYPAL account: BMWXENON@aol.com) & ALL TYPES OF MAIL PAYMENTS. Sorry NO Bill Point Payments at this time.
Appreciate your input.
hroussard
You can get superwhites from $5 to $100 depending on who you buy them from and how much of a markup there is. Sounds like a ripoff to me (anything over about $40).
  • 3 years later...
What about heat/lens discoloration when using these for fogs (to match my HID
converted low beams)........any issues?
I have factory xenons and I also have a few different HID kits like the ones you mentioned from ebay. I tried to use the HID kit for my high beams and also tried for the foglights. It looked very nice but it didnt work out well because there was no reasonable place to put the ballast. Since the factory ballast is behind the headlights, there was no room in that area. I tried several different options and nothing worked well. The only option that worked was to put the ballast in the trunk compartment and feed the wires through the hole where you put the tool to remove the headlights. That only worked for the foglights because the wires were not long enough for the hi-beams. When I used the xenon bulbs for the foglights, I could feel a lot of heat over the lense, I decided to take them out immediately. I really didn't want to ruin a good set of litronics.
Xenon bulbs works with electrodes ( same principle as an electric or tig welding unit ) not with filament's as halogen bulbs.
