I have a 2001 Boxster S (21,000 miles) with OBC, and PCM 1. I live in Canada where NAV disks never were, and are not available. If I replace the PCM unit will I lose OBC functions that currently display on the instrument cluster. I know that certain OBC functions are displayed on the PCM but I do not know if they originate in the PCM as suggested in some manuals. Has anyone done this or a similar swap? (Porsche NAV for aftermarket NAV).
OBC is a separate computer so the functions in the cluster should not change.
Any OBC displays in the NAV will not be there with an after market NAV.
To be short, PCM need OBC - OBC don't need PCM
Thank you.
