My starter is experiencing the "elephant" sound as described in other posts on this forum. I am having the AOS replaced this later this week, looks like the starter is close by at the top of the engine. Just wondering, replace the starter or just lube the problem area? If lubing is suggested, is there any information on where on the starter one is to lube and what lube to use? 99 Box: Original starter 90K miles.
Thanks.
Ed
I should replace or repair the starter, lubricating the gear and axle mechanism is not always sufficient at that mileage. It's up to you.
