I have a 2000 996 with the headlamp washers. Tried them for the first time and one of the nozzles on the left side came out of it's socket and hit the windshield as I was cruising the freeway. Can you just replace this portion of the washer or do you have to replace the entire assembly. If the answer is yes where can one get the nozzle or an assembly less than $135.00? Is it difficult to install?
i lost three of them by now. crapy quality. dealers gave me replacements from broken lamps. never managed to buy just that part. hope you have better luck
Got the same problem a couple of months ago. You have to buy the all thing, not just the cover and it´s a easy DIY job. There´s a lot of parts supliers from UK ( do a goole search ) and they will ship it to you . Csot was around 60 Euros
Luis
  • 9 years later...
