98 Boxter, cel, code reads sec air injection system, Does any one know what this means and how to fix it, I would like to do it myself if I can, Thanks Ross
P0410 Secondary Air Injection System - Signal Implausible (Cylinders 1 - 3)
Secondary air injection pump is not triggered.
Potential causes:
- Wiring harness or fuse
- Relay
- DME control module
- Air supply lines
- Secondary air injection pump
- Electric change-over valve
- Air change-over valve
Thank you very much Loren, I also have a smell of gas in the cabin could this be in anyway connected, or help pinpoint which one
Left rear luggage compartment. There is a relay panel there.
The 40A fuse for the secondary air pump and the relay for that pump is in position 10 of that relay panel (993.615.115.0).
