what up
so dummy me :oops: accidently left the key in the ignition and the battery was on its last leg. i understand you can release the hood with a cable located in the front right wheel well. after searching here in renntech and on my 02 996 cab, i could not locate it! anyway, if someone has performed this and could give me a little direction as to where this cable release is located it would be greatly appreciated :thankyou: do i have to remove the wheel and the wheel well cover for this??
thanks, bobby d
what up
thanks, bobby d
Not sure if it's the same but on a 997 there is a red terminal inside the fuse box that you can grab and pull out. Hook the + side of a batery charger or jumper cables to it, and the - side to the door hinge or something solid metal and you will have enough juice to open the hood. Maybe easier than fishing for the cable.
Good luck
PB
dude thats great and all but its not a 997 and im NOT trying to do a fuse box hook up but thanks
bobby d
You have to remove the wheel and the front part of the inner wheel well, the cable is located behind and in the environment of the water tubes ( if you are the first one to do this ). aintpatricksday suggest is easier to do.
what up
thanks, bobby d
Good luck
PB
aintpatricksday, dude sorry for my arrogance and ignorance. your absolutely right! much easier to utilize the positive hook-up located in the fusebox! your a champ yo! :renntech:
:thankyou: bobby d
