Hello,
I have a 99 996 C4 with around 18K on a replacement engine. The car has 39K! I'm having an annoying issue at idle, the RPM's fluctuates between 800 to 900 constantly. A few times it dropped below 500 and almost stalled!
I changed the air filter to a BMC, cleaned the MAF which had very little build up and I still have the issue. The O2 sensor was changed just before I purchased it as well. With these low miles there is no way the spark plugs and ignition coils should need to be replaced, right?
I'm stumped! :( :unsure:
