Hello, so this is the problem I am facing now. I have a boxster 98 2.5 tip that I upgraded to “1999” 996 3.4L. I am using boxster harness modified the harness by adding ground to pin 58. It seems to me the car is running rich. You can smell it from the exhaust; also the car loses gas real fast. When car is running and I step on the gas black smoke comes out of the exhaust. The car runs strong and doesn’t seem to lose any power; the only noticeable thing is the black smoke and of course losing lots of gas. I hooked the computer to both PS2 and OBDII and these are the codes I found:
PS2: P0157, P0300, P0301, P0304, P0137, P0131, P0151
OBDII: P0157, P0300, P0301, P0304, P0137, P0151, P0131, P1115, P1119, P1319, P1313, P1316.
At this point I am not sure what’s causing the engine to run rich... ECU, O2 sensor? Help please
Ali
What DME are you using? and did you re-program it?
i am using the original boxster DME unit, but i flashed it "reprogrammed" to the 996 riginal "not sport or after market re-programming".
Ali
OK. Finally problem solved:
1) I had 3 bad O2 sensors, and I know why. Well actually I got 3 after market O2 sensors "$18 each- I was curious". I cut the old sensors connectors and reconnected the wires from new sensors to old connectors. Now I am not sure if the sensors are not good for boxster’s application, or if I made a mistake and miss-wired. As a solution I got 3 new O2 sensors and that resolved the issue. "I shall get the after market O2 sensors try and re-wire them see if I can make them work". Car did not run rich any more, no smelly exhaust or black smoke.
2) The second part of the problems was caused by a leak in the cold Air intake hose connecting air throttle body to air intake cone. All the after market hoses I purchased "as much as $375" did not work and kept leaking air. I think they did not work because they were designed to fit a car with e-gas air throttle “which points opposite direction from none e-gas. At the end I got 3" aluminum pipe + 2 x 90 degree silicone hoses + 2 straight silicone hoses and D-clamps. Customizing cold air intake hose is the way to go. Looks nice, fits perfect. No more Air leaks and no more CE warning!!
"p.s i shall add pics later in my '2.5tip to 3.4 conversion' post"
A serious thank you to Loren and Todd, you guys rock
Thanks again
Ali
:renntech:
Ali
Thanks again
Ali
:renntech:
Do you mind posting the info on the generic o2 sensors that you used? Where did you buy them? Did you do any special type of connection from the old wires - new?
Ali
Thanks again
Ali
:renntech:
I shall post the info soon, I will try and correct my wiring and use all 4 generic sensors this time "last time I used 3 generic and one factory original". I got the O2 sensors off of ebay for about $25 each I think "on ebay under boxster parts". I shall rewire, reinstall and see if that resolves the problem.
Ali
Thanks again
Ali
:renntech:
Goldnogard
What kind of fuel mileage were you getting when it was running without all the CEL's problems
Catman
Ali
Thanks again
Ali
:renntech:
Goldnogard
Catman
The CEL problems started right after i installed the 3.4 on my boxster, so i always had the CEL lights from day one. after swapping the O2 sensors + fixing the cold air leak, thats when all CEL codes were corrected. only now my 3.4 boxster runs normal "i am guessing it has the same fuel mileaga as a 996". if you have other ways of telling fuel mileage let me know and i shall test.
Ali
