Cayenne mObridge installation (w/images)
I recently installed my mObridge Audio device in my Cayenne Turbo, and wanted to share a bit of experience for anyone considering the same path. I opted to do the install up front in case I needed to access the device for firmware updates. The rest of the options for the device are easily relocated, but to use the SD card access for music or for flashing the firmware requires physical access. The best location I found was the panel directly behind the glove box. There is a s
Edited by 3ball
  • 7 months later...
Since the install, I have learned to use the button set. To advance to playlists, you hold the "next song" button down for a few seconds to enter the playlist tree. Then hold the "next song" button again for a few seconds to select the playlist. Fairly innovative, given the limited integrated controls they had available. I have since modified my center console to hold my iphone, but now I am working on a more visible implementation. I will update with pictures in the coming month.
  • 6 months later...
Hi 3ball,
I'm going to get a mObridge soon and i wonder do u need to take out your PCM unit ?
Do u know how to remove the trim part or how to take out the PCM ?
Thanks!!
