Loren, my 01 996 turbo has a creaking noise in the bell housing, can I follow the 996's TBS "7/00 3041 Creaking Noise in Clutch Bell Housing Area 12-22-2000" to fix the problem? Thanks
The TT uses are different transmission and clutch from the 996 - so that TSB is not relevant for the TT.
It could be a worn throw out bearing or the clutch disc may be just about gone.
How many miles on the car?
The car has about 40K.
Could be that the clutch is about gone.
I let a technician check the clutch disc about two month ago, he said the clutch is fine. If I have to drop the gearbox, where can I find the procedures? Thanks.
