Hello,
I opened the engine compartment (side and top) to check the polyrib belt (it looks good, but I think I'll replace it anyway since I am over 60K). While looking around I noticed a cap, in the engine compartment, on top, kind of behind the driver's seat that has a loose hose. On top of this cap it says something about "Hydraulic only" - the picture I took didn't come out right and I can't remember exactly what is says on it.
What is this hose and is it OK to stay open like that? Does it need to be plugged anywhere?
Also while I was in there I noticed that the insulation was ripped and it was actually touching the belt... I ripped the broken parts out - I figured it's better to be without than to touch the belt. Is there anyway I can replace that insulation?
azzar0.
Power steering pump/supply (use on Pentosin per your Owners Manual). The tube is just a vent - it does go nowhere.
Vent hose is: 986.314.545.00 Hose -- US MSRP $11.14
If you need the clip it is: 999.512.527.00 Clip -- US MSRP $2.02
I'm sure Sunset has better prices since you are already placing an order with them.
Whew, that's a relief!
What about the insulation? Should I worry about replacing it or just leave it out?
What is the clip you mentioned for?
I apologize for all the questions, I am still on a stiff learning curve here...
azzar0.
