Brake pad DIY
C4S Surgeon
I think they are just bigger and more rectangular - if you are using stock pads they should just press into the slots.
They also have a pressure clip. thanks again.
Addendum; just did the fr/rears 1.5hrs. Not too keen on the rear setup, now you gotta pull the caliper to put the pads in, prefer the old 996 style. Overall, easy DIY job.
Edited by C4S Surgeon
