I have a 99 boxster 2.5L manual. I have had a problem with CEL light with rough idle and rpms fluxuating between 800-1000rpm. CEL codes led me to the MAF sensor. Replaced sensor CEL stays off. Still have rough idle with rpms flux. Removed and cleaned the throttle body which helped the rough idle still have fluxuating rpm between 800-1000 rpms at idle. Any suggestions. FYI - when I removed the oil seperator tube from the throttle body had a little oil in it. I have read that the bellows may fail causing idle fluxuation. Could this be the problem and how do I check it?
