Hi all,
Just posting these details on my 38K miles '99 C2, in case anyone finds it interesting...
Normal running temp : about 200 degrees
Ammeter : is usually at 13V normally.
Idle RPM (a/c NOT on) : 650 RPM 2.2 bar oil pressure (seems a little lumpy at this RPM, much better at 800)
Idle RPM (a/c on) : 800 RPM 2.5 bar oil pressure
@ 1600 RPM, oil pressure is 3.2 bar
@ 2000 RPM, oil pressure is 3.5 bar
@ 3000 RPM, oil pressure is 4.5 bar (this is about as high as it gets)
Fuel economy averages between 18 and 23 MPG. I use super grade fuel.
The car seems healthy, no problems that I know of. No oil leaks.
-James.
