In August '02 there was a TSB issued for "Body - Noises From The Door Lock Area" Does anyone have any info on this. I had my '02 Cab in for a jingling sound coming from the door lock area when the top is down. The dealer was able to fix a number of rattles, but couldn't find this one. I'm wondering if this TSB specifically addresses the problem that I described.
Vehicle Type: 911 Carrera (996) /911 Carrera 4 (996) /911 Carrera 45 (996)
Model Year: As of 1999 (X)
Concern: Clicking / grating noises coming from door lock area.
Information: Clicking / grating noises coming from the door lock area are caused by the catch bar rubbing in the door lock.
NOTE: It is not necessary to replace the door lock.
As described in Technical Bulletin Group 7, number 3/00 complaint 5, the door lock is to be sprayed with silicone spray, The silicone lubricant spray is now available as a spare part from PCNA parts department.
Parts Information: Part Number 000 043 204 40
Description: Silicone lubricant spray
Complaint 5: Grating from the door lock
Cause: The catch bar is rubbing in the door lock.
Repair: Spray the door lock with silicone lubricant spray. Spray in the inner area of the lock, in which the catch bar engages. See arrow in figure 8.
Notes: Do not use greases or other lubricants on the door lock. They attract dirt and will cause mechanical problems.
