when i turn on my headlight, they are very dim. the only way that i can see at night is if i turn on the fogs lights. any idea what might be the problem?
Is it a ROW car without transformations ? If yes, check or let check the day driving lights program to start with, afterwards the grounding and the power supply ( voltage ) of the headlights.
I think it's even simpler than this. It sounds to me like your headlights have burned out and you're using just the running lights. Go to your local auto parts store and get a pair of H7 bulbs (I like the Silverstar). Take the headlight module out of your car and replace the lamps. It'll take you about 15 minutes your first time, and about 5 minutes the next time. It's a very easy job.
Tune in next week when we discuss not paying to have your brake pads changed. :P
-Michael
-Michael
I'm having the same problem, what was the fix?
