a few options out there
-emergency cable should be located behind the passenger(US) side headlight( inside fender well usually)
-unlocking the lever by using a small screw driver
-locate looped latch cable inside the drivers side fender well then jerk(US)
-get a cigarette light booster to unlock/charge battery
As Loren mentioned ,do your search U might be able to get more info.
