well im a t a loss! i have a 02 996 tt with pcm (have that code ) but when i put it in it wont accept it so im figuring on it also needs the navigation code but thats not illuminated are there certain buttons i have to push together to get me over to the navigation screen??thanks
The PCM 1 code is wrong or the unit is already replaced, sometimes you have to push in the navi. code after the PCM 1 code, sometimes not it depends what is happen before. In case the PCM unit is replaced i will hope that the tech. pushed in the new codes in the DME section as info, so that the dealer can pick up the codes.
