I recently did the 4-stalk install, carefully following the instructions.
Ever since then my airbag spring has been very noisy and squeaks every time I turn the wheel.
Any ideas what went wrong and how I can get this thing to be quiet again?
I taped it and didn't allow it to move while I was installing the new stalk.
The male part of the spring assembly fits snugly into the female hole in the new 4-post stalk.
What part of it could I grease? It seems like a sealed unit.
The "squeaking" sounds like if you were to twist a slinky, hard to describe. A sprung metallic sound.
Yes, the round black assembly that bolts on to the 4-post stalk with 2 screws. When it rotates it makes a noise like metal grinding on plastic. I do not have any related codes or airbag lights.
When you re-installed the four stalk switch did you position the switch assembly to the corect depth on the steering column before tightening the pinch collar bolt. The correct depth is 2.16 inches plus or minus .02 inches.
