Hey guys,
I have been getting a CEL after i had my ecu flashed.
p2188
p2098
any ideas what these are? thanks
edit: nevermind i just figured out how to get the codes from this site, how do i delete this post though?
Edited by raffi
P2188
Lambda control adaptation FRAU (lower load range) - below limit value
Lambda control adaptation FRAU (lower load range) - above limit value
Lambda control adaptation RKAT (range near idle speed) - above limit value
Lambda control adaptation RKAT (range near idle speed) - below limit value
They need to look at the FRAU and RCAT readings to see which issue it really is.
P2098 Lambda correction downstream, bank 1 – rich/lean control limit exceeded
Possible fault causes:
- Leakage in exhaust system between the two oxygen sensors
- Oxygen sensor upstream faulty (contaminated/aged)
This one is likely caused by the primary fault (P2188) - as I said they need to look at FRAU and RKAT.
LOL -- VAG codes are VW and Audi specific.
P2188
thanks loren,
you are the best.
