Hey guys,
I have been getting a CEL after i had my ecu flashed.
p2188
p2098
any ideas what these are? thanks
edit: nevermind i just figured out how to get the codes from this site, how do i delete this post though?
Edited by raffi
Model and year of car please?
thanks loren,
the company which flashed my car is very helpful but they say they need generic vag codes.
2005 997 carrera S
P2188
Lambda control adaptation FRAU (lower load range) - below limit value
Lambda control adaptation FRAU (lower load range) - above limit value
Lambda control adaptation RKAT (range near idle speed) - above limit value
Lambda control adaptation RKAT (range near idle speed) - below limit value
They need to look at the FRAU and RCAT readings to see which issue it really is.
P2098 Lambda correction downstream, bank 1 – rich/lean control limit exceeded
Possible fault causes:
- Leakage in exhaust system between the two oxygen sensors
- Oxygen sensor upstream faulty (contaminated/aged)
This one is likely caused by the primary fault (P2188) - as I said they need to look at FRAU and RKAT.
LOL -- VAG codes are VW and Audi specific.
P2188
thanks loren,
you are the best.
