i check the Radiator Fan fuse and relays both ok.....
i try to stage 2...(turn the AC on)...... the high speed fan not working....
so..what i need to do next ...
thanks ~
Um... where are you located?
It is pretty unusual to lose a fan motor. It would be best if you can find someone with a PST or PIWIS to confirm your findings.
Toronto, canda ~ PST OR PIWIS means comupter ? check the fan ?
PST2 and PIWIS are both Porsche diagnostic computers - most good shops have one or both.
Yes, check the fans using the tester.
thank you ~ i will find a shop. i want to know . if i didn't fix this . have any problem there ? because it's one year ago................( i never know have problem with fan....)
i have make appointment with porsche. but only one in the toronto area... the date- JUN 7 ,2008 ~ i don't like waiting for long time ~
every advice is very importance ~
Disconect the fan and ballast resistor cable. There are 3 pins in the connector, the black wired pin is the common ground (earth). The other two are the low and high speed leads to the resistor. The low speed wire will have an impedance of approx 1.4 ohms, the high speed will have zero resistance. To start, put the leads of the ohm meter on the taps at the motor. This will give you the impedance of the fan motor. My motor measures 540 ohms. The high speed line should measure the same and the low speed should measure 1.4 ohms more. I had 2.3 megohms resistance through both high and low speed lines which means the resistor was totaly fried. With some dexterity, this can be done without removing the fan assembly from the car. Check the resistance trough the pins first, if they are high, (thousands of ohms), the ballast resistor has failed. Then remove the fan assy and replace the resistor. I did all this yesterday, resoldering the new resistor is easy. Be careful not to get anything inside the fan motor.
James Greer
James Greer
thank you james, i will follow your way try to fix this ...
