My 1998 Boxster is experiencing a dead battery problem. After leaving the car overnight there is no juicer to power any part of the car. Can only be started using an outside battery. I took the car to a local Porsche specialist who, by process of elimination, determined that the problem lay in a fault in the instrument cluster which is drawing power even thought the ignition is off and key removed. Among things checked and eliminated as a cause were the ignition switch and the alternator. Estimated cost to replace cluster plus diagnosis is $2800. Is this common , rare, or unheard of? Are there any other possible causes which should be investigated?
Thanks for any ideas or guidance
ranger01
The dealer can check with the PIWIS tester, in the menu "wake up guardian", which control box refuse to get a sleep or wake up after a well defined time.
My 98 drains in about 5 days, from brand new battery install, The Horn is one place it has been draining, removed the fuse but there is still a drain, I think it has something to do with the alarm as the alarm horn has been disconected when I bought it ,Please keep us up to date as to what happens as the drain fried my alternator already. I had a 5 and a 3 BMW that had the boot light that stayed on after it was shut (Sometimes) and that drained the batt also.
