I have a MY00 C2 and wanted to add GT3 control arms. Do I need to upgrade the links as well?
Loren, do you have the part numbers for the items I would need to get the install right?
Tom
Are you trying to get more caster or more camber?
Just more camber. I think I got the answer, but please let me know if this won't work for my 00 C2:
996-341-121-90 - right conrol arm
996-341-122-90 - left control arm
996-341-441-90 - inner arm (X2)
shims and connecting pieces
And by "links" above, I actually meant the inner arm for the 2-piece control arm, and not a control arm link. I couldn't really figure out what the names were. And they still might be wrong...
Tom
Edited by td873
Those are correct - now you will need to choose the right shims ;)
Is there a DIY for this? I'm certain that the alignment will need to be a "shop job" since the new control arms will probably change caster and toe...
Thanks again,
Tom
