Hello
I am a new member and was looking for anyone who may have changed the transmission ( or Gearbox) fluid in a 964 C2. I have some basic information and know where the drain and fill points are, I also know the volume and have some Swepco 201 80/90 fluid or Lube, which has some heavy weight recommendations across the Porsche racing community.
My biggest problem is I will be doing this operation on my drive, with only basic ramps and axle stands to get any operating space under the car. I can imagine the access to the drain point will be OK, but I can see that filling may present a problem, as I don't think it will be possible to pour in the oil with the transmission in place, I imagine it will need to be pumped or squeezed in somehow ?
If anyone has any experience or insight into this task, any advise would be appreciated ( please do not tell me to take it to a dealer, that would be to easy !)
Many thanks
:welcome:
Many auto parts stores sell a pump that fits right on the end of the gear oil bottle that allows you to pump the contents into transmission.
the drain is on the bottom and the fill is on the side, sorry no pictures to back it up.
one thing that I have found is when you put swepco in a car that has a lot of mileage it makes the syncros too "slippery" and you get gear grinding since the syncros are not slowing down the gears for engagement enough
I used a long piece of tubing and threaded it from the fill port through the left rear wheel well. I squeezed the bottle and used gravity for the rest. This was a PITA and would highly recommend trying a pump. I will for my next go at it. With regards to the Swepco, I've had the same experience.
