I am buying a Boxster with a price limitation of $30K and have found a nice 2003 S with 20K miles and a 2005 base model with 34K miles. Not sure about the pros/cons between the 986/987 platforms in terms of reliability. Consumer Reports says to stay away from the 2003 Boxster because of repair issues. Is this true?
I should also mention that I'm a tinkerer and will most likely be enhancing the sound system, adding navigation of some sort, tweaking bits and pieces to make it "mine". Not sure which platform is easier to work on.
So, 986 generation 2003 S or 987 generation base model... What do you think?
Thanks in advance!
