Any help with convrting my PST2 system to a laptop. I copied the HDD and now I want to put it on a laptop to do diagnostics.
Curious how did you copy the hard drive?
First question is why are you converting your PST2 system to a laptop? I am guessing that there a problem with the PST2 but the HD is fine? I would suggest you buy an IBM 600E or t21,22, or 23 and just insert the hard drive into the IBM. Insert your KTS card and you should be fine. There will be problems using the HD or HD clone in just about any other laptop.
Oh and first I would use the actual HD out of the PST2 in the IBM unit. The PST2 HD is very hard to clone properly.
Edited by Porschelibrarian
