Just want some experiences people have had towing - want to tow either a GT3 or spec Miata in an enclosed Trailex aluminum trailer (empy weight 1800 lbs) with an S. Shouldn't be a problem should it?
I tow a 20 foot boat and my 69 911 race car with a open trailer.. The only problem I had was when a trailer was connected right signal on and braking caused a check trailer light to go on.. A updated control module solved that problem. If you ordered Air suspension you will be very happy with it. I can cruise at 85 without even feeling the load behind me.
Looks good in black- my will be black/black. Are those 22's??? A little stiff ride? Yes I'm getting air suspension should that should be great for towing.
Great color combo choice! Yes those are 22"s. Actually the ride is just fine.. I went for a ride in mine then immediately jumped in a steel suspenion S with 18" and mine was actually smoother. Good choice on getting the PASM.. you will be pleased!
Kevin- what kind of brake controller do you use? I heard of troubles with wiring them and lots of conflicting stories.
Skl, I used the Prodigy Tekonsha... I think my wiring is incorrect, although it was working when I used it, the numbers were jumping around, so It needs to be wired directly to the brake switch.
