I have a 2001 996 TT with 16,000 miles. On heavy acceleration I get a check engine light and the car sputters and goes flat. As soon as I let up on the gas the check engine light goes out and the car runs great. This always happens when if I accelerate hard from about 3000 rpm and sputters all the way up to 5000 or until I let my foot off the accelerator. Any Ideas?
thanks,
Joel
I checked the faults with an OBDII code reader and it said zero faults. Does the Durametric have the capability of reading codes in a history that are no longer active?
thanks,
joel
If your check engine light comes on then there should be a code. Very few codes clear themselves on the sane drive (usually takes several drive cycles).
What did you use to read the codes?
Also, where are you located?
The check engine light only comes on for about 5 seconds, while the car is stumbling, when I let off the gas the car quits stumbling and the check engine light goes out. While the check engine light is on the center dash says to drive to a qualified repair shop. I am in Portland.
Joel
Is your car modified? Sounds like my experience with a bad MAF, definitely check the codes and get back with Loren, he'll lead you in the right direction.
Joel
thanks,
joel
You need a better code reader...if the CEL came on there are codes to be read. Get the durametric...
As I recall....the P0301 is a cylinder misfire on cylinder #3....bad plug or connection? I had a series of the P0XXX for a while, but it showed up on multiple cylinders and also a "random cylinder misfire" . They always showed up after a hard drive...finally the dealership changed out the MAF and the problem stopped.
