I'm looking for a wiring diagram to install a relay so that I will have running headlights on when the ignition is turned on. The car is from California and I require running headlights in Canada. Thanks.
2001 Boxster S 3.2
6sp transmission
2001 Boxster S 3.2
6sp transmission
Check this out... It might be exactly what you are looking for.
I have purchased from these guys before - good products and delivery
Daytime Lights
Best,
Gus
2001 Boxster S 3.2
6sp transmission
You don't need a kit. Just go to the link below
http://www.whiteson.org/boxster/mods/drl/
and follow the directions. I did the mod on my 99 996 Cab (US spec car that is now on Calgary). It cost next to nothing, passed the RIV test and has been working fine. I couldn't find the little taps they talk about at Radio Shack as that doesn't exist in Canada anymore (The Source has eliminated the part number). I made the taps out of small strips of copper sheet (scavenged from copper plumbing pipe straps) and soldered the wires to those. It actually makes a cleaner installation than with the taps and the connectors. Good luck.
