Airbag light diagnosis Fault 271
Hello folks --
Has anyone run across this fault before. I took this to the Porsche Dealer to clear out the Memory Fault for the Airbag light. There seems to be a constant fault. The intial diagnosis is that the passenger side airbag needs to be replaced.
Fault 271 Ignition Ciruit, Passenger in the Airbag Module
2000 C2 Cab 6 speed
Any thoughts?
Nevermind I will follow up on this forum. The tech gave me the wrong fault number its 27 not 271
http://www.renntech.org/forums/index.php?showtopic=18417
Tom
Edited by mcliquid
