i had a small nut roll under/behind the accelerator pedal
i removed the long screw at the top, but nothing moved
am i missing something?
aloha
steve
Once you have removed the long screw on the top left then you lift up on the unit. At least that is the way on a non egas car.
97 Boxster-
You might have trouble pulling upwards due to the return cable [pulling down].
Believe me - DO NOT pull on the peddle thinking it has a press fit on the lower portion. It is held in by a long screw running the width [along the bottom]
It also has approximately 4 screws holding the assembly [gas pedal] together.
If you pull on the pedal and not the whole unit you will pull the flimsy hinge apart, and then you will be in a world of hurt.
You will need to disassemble the gas peddle in a space meant for gnomes.
You will need to be creative and screw it onto the base of the peddle to retain it in a controllable flex versus a floppy peddle.
I have not tracked down the return cable location, but it is somewhere under the floor pan.
I will leave that identification to Loren or Tool pants.
Edited by mrmickeymouse
