Hi there,
First post and it's a request for help!
I am looking to fit the following wheels on my 2001 Boxster S....
Front - 8J x 18 offset ET57 p/n 997.362.136.00 225/40
Rear - 10J x 18" offset ET58 p/n 997.362.140.01 265/35
What spacers, if any, would I need to fit them to my Boxster?
Thanks for any advice!
best regards
McBee
H & R TRACK+ 7mm
Hi there,
best regards
McBee
Hi there,
best regards
McBee
7mm spacer should work for the front. In the rear, you'll want a 10mm-12mm spacer.
Hi there,
best regards
McBee
Sorry for the ignorance, but how do you guys calculate these numbers... I know what the suggested OEM diameter, width and offset are for my model (986). How do I go from there if I want to look at aftermarket wheels which do not match the OEM width and offset? How do you add spacers to that equation?
Thank you so much,
Gus
Edited by gandrade1
Don't
Hi there,
best regards
McBee
Thank you so much,
Gus
Edited by juniinc
