Can someone tell me how to remove the Bose bass enclosure from a C4S coupe? I don't see any obvious screws. There are some "slots" at the back, but they don't seem to be hinged and I couldn't see inside to idetify any connectors. I'm probably over-looking something simple, but I don't want to damage anything.
Easy...
The plastic piece/frame on the canons that says "Bose" on it can be removed - just snaps out (very fragile though!! I borke one while removing so had to buy a new one from dealer). Once you do this, you will see a large toex screw behind each of these (I think T-30 or T-35). Remove the two screws, the whole sub box slides forward and then idsconnect the cable that will be behind driver side on back of sub and you are done!! 10 minute job (not even)
