I'm hearing 2 annoying noises - 1 from the dash (can't figure out exactly from which part - I believe is where the leather and the plastic are uniting) - close to the windshield and the 2nd one from the passenger’s seat – when empty – when occupied I don’t hear the sound…
Any suggestions?
I have the same with the passenger seat. The rails/levers underneath generally 'rattle'. Try slightly lifting the seat (if electric) at front and back and changing the angle of the backrest. That generally cures it. The noise near the windscreen could be what i have mentioned on here before. It could be the rubber that goes round the screen on the outside rubbing against the body/paintwork. It causes a 'creaking'. You need to clean under the rubber seal and then add silicon grease to stop the noise (if it is that?). Do a search on here reference windscreen noises etc.
