My '02 Targa 996 has a minor, intermittent issue.
Sporadically, the message "Failure indicator" appears in the OBC window, and at the same time the oil pressure guage falls all the way to the bottom. This only lasts a few seconds, then the oil pressure guage is back up to normal and the failure indicator message goes out.
My car is under warranty, so I know I could just have the dealer check it out, but I thought I could at least check for loose connections around the oil pressure sending unit, and maybe save the time of a dealer visit.
I would be very appreciative if someone could describe where the oil pressure sending unit(s) is located and I would also appreciate any other tips if anyone has had a similar problem.
