My 2000 Boxster has beeen refusing to start lately. It cranks and just won't fire. It's like it's not getting spark for some reason. When you let it set, it sometimes fires right up and has no problem. It also sometimes won't start on first, second, or more tries, and then fires up on subsequent tries. It seems to be random, because sometimes it immediately fires. Once started, it runs fine though.
Any thoughts?
Any thoughts?
Andy:
You started this thread under the heading of "987 Boxster Top Issues and Solutions". You should try to get this moved to the correct sub-forum to maximize responses.
On the topic... Have you noticed any unusual electrical glitches lately?
Also, locate the clutch disengage switch (behind the clutch pedal) and jump the two wires (to bypass the switch) and see if you get consistent starting.
If you do, then you have isolated the problem and replacing that switch is pretty straightforward.
Since the engine will crank and not fire, i should go for the relays ( DME - fuel pump, etc. )
Happened to my 1998 boxster a few years back after it sat for 2 months. I called the dealer and they had me keep the key in the starting cranking position with the gas pedal down to the floor until it started. A puff of smoke came out and it started and has ran well for 5 years now.
  • 3 months later...
What this does(on the cars I have worked on, may be diff for porsche) when you got WOT with koeo, then go to koer position is it cuts ALL fuel to the injectors, helping/trying to remove any unburnt fuel in the cylinders
Any thoughts?
Andy,
I have this same problem with my Boxster, a while back and now every time I refuel. Do you have an evap cannister fault code? If so you may be getting a potential vapor lock due to any/all of the following:
Charcoal cannister
Vente tube
FUel filler neck shutoff /purge valve
All located inside RH wheel liner by the filler neck. This may help...I have the P/N's too.
Chris
00 Boxster
161K miles
i just experienced this exact same problem... without warning, the engine cranked fine but it just wouldn't start. battery power was good. fuel pressure was good. after searching thru the forum and thinking that it might be the immobilizer, i took Zjuan17's advice and held the gas pedal down while cranking the engine... sure enough, in about a minute, the Boxster fired up and has been running solid since. unbelievable! thanks everyone!
-dg
