I have a strange problem with the hydraulics on my rear wing. When I lift the wing, the right hand side lifts much quicker than the left and when the wing stops lifting, the right side is higher than the left.
What could the issue be?
Also, the banjo fittings at the base of the rams on both sides are slightly damp. Is the system low on fluid?
I just went through this same problem. It is either the hydraulic pump or the rams are leaking due to a crack in the pump,
bad seal on the ram on the left or both. I am sorry to tell you a simple fix is not in the cards. I tried to have mine fixed and
it ended up costing more to try and fix the problem than it was worth. Porsche reccomends replacing the whole hydraulic system
to the tune of approx. $1900.00. In the end I decided to replace the engine lid with a GT2 type engine lid and wing. I'll
never have the problem again and the new wing looks awesome. If you decide to go the GT2 Wing route. I got mine from
MA Shaw company primed and ready to paint with the necessary wiring harness for $1850.00. Add maybe $300.00 for paint and your done. You can easily install it yourself
