hi when i remove the plastic cover uppper from the air cabin filter removing the screw the rubber with the screw inside wich fix this cover braked
i mean when i try to screw again the the ring come out of the rubber and the cover placed without the screw could tight i need the part number of this rubber
where the screw screwed
if you could give me for the rubber of the other drivers side too because i thin this is old too
thanks christa
i need too the plastic screws wich 2 of them keep the passengers side foam cover down in passengers foots down from the ventilation "the black foam cover"
keeped in place
For the pollen filter cover: 999.500.092.00 Nut (rubber coated) -- US MSRP $2.94 each
Not sure what the other two screws you are asking about are?
Are the in the footwell?
Are they in the carpet or in the heater mechanism?
  Loren said:
Are you taking about the battery cover hold down screws? (item 11)
no no in the hood
i remove from the passegers side in front of the seat under the console the black foamy cover to see the motor of the flap . this foamy cover holded by 2 plastic small screws with "big head" this screw screws on the plastic climate box where inside is the ventilalation rotor of the passengers side foot heating
  Christa said:
no no in the hood
Loren, she's talking about a foam sound absorption panel under the passenger side of the dash. I think the plastic screws are 1H0.819.943. My version of PET is not very descriptive. --Brian
Edited by Q-Ship986
