hi when i remove the plastic cover uppper from the air cabin filter removing the screw the rubber with the screw inside wich fix this cover braked
i mean when i try to screw again the the ring come out of the rubber and the cover placed without the screw could tight i need the part number of this rubber
where the screw screwed
if you could give me for the rubber of the other drivers side too because i thin this is old too
thanks christa
i need too the plastic screws wich 2 of them keep the passengers side foam cover down in passengers foots down from the ventilation "the black foam cover"
keeped in place
For the pollen filter cover: 999.500.092.00 Nut (rubber coated) -- US MSRP $2.94 each
Not sure what the other two screws you are asking about are?
Are the in the footwell?
Are they in the carpet or in the heater mechanism?
Are you taking about the battery cover hold down screws? (item 11)
no no in the hood
i remove from the passegers side in front of the seat under the console the black foamy cover to see the motor of the flap . this foamy cover holded by 2 plastic small screws with "big head" this screw screws on the plastic climate box where inside is the ventilalation rotor of the passengers side foot heating
no no in the hood
Loren, she's talking about a foam sound absorption panel under the passenger side of the dash. I think the plastic screws are 1H0.819.943. My version of PET is not very descriptive. --Brian
Edited by Q-Ship986
