Hello Gang,
Regarding my MY 2000 2.7 986: Three Years ago I replaced the stock CDR 220 head unit with a Traffic Pro GPS unit. All worked well for 3 years.
Two weeks ago the GPS stopped working, most likely because the externally mounted antenna got wet and became corroded. In the process of trouble shooting the problem I removed the head unit to check the GPS antenna connection in the back of the head unit.
I stopped working on the problem for a week. Then the car would beep once after locking within 5 seconds. I replaced the Traffic Pro with the original CDR 220 AND THE PROBLEM STOPPED!
However, after one day the same problem started again (beeping 5 seconds after locking.)
I've ordered the Durametric Scanning tool, but until it arrives I wonder if anyone has any ideas.
THANKS
Best Darn Forum!!
I put some electrical tape on the metal connector and the problem went away. Weird since I was using the OEM head unit.
NOW to find a replacement antenna for the the GPS unit . . .
