I have seen the many DRL threads, but I hae a new question. Is it possible to use your fog lights as DRL? It looks like from the fuse chart that to use your low beams as DRLs you jump the A-6 (heated seats) to the A-9 (low beam right that is jumped to low beam left A-10). The fog light fuse is A-7 which appears to already be jumped to A-6. Is there a way to use your fogs as your DRLs? Thanks.
Will
Sorry I can't help with your question as I don't have the wiring diagram in front of me but do you need DRL in SC? I thought it was a Canadian thing only.
Yes there is
one way would be turn on ur fogs while u are driving? hahaha
my LED fogs are wired with the ignition sw, so they come on whenever car is running.
No it is not required in SC. My wife's Acura gives you several options as to DRLs. Hers is set to use only the fogs. Looks cool and I thought it would be a cool option for the P car.
Will
Yes there is
Okay, short of manually turning them on. Anyone else?
