I found that my driver side fan is somewhat hard to turn by hand. The passenger basic spins freely when spun by hund (obviously car not on). I bhad replaced the ballast and drivers fan ran for a little while. Then after I got everything buttoned back up started the car again and no drivers side fan. I started to notice some smoke and noticed that the ballast resistor I had just replaced was smoking. When installed it was a black color. After a minute or so it was a brass copper color. Burned my hand when I touched it. So I assume that the fan is locked up and this is causing my problems. Question is has anyone replaced the fan? I haven't found this anywhere on the website.
Looking for radiator fan replacement instructions. Thanks
The most easy way is build out the complete radiator and than remove the fan.
