99 996 US
Car jumps from close loop to open loop and back several times at idle.
and the airflow reads only around 0.8lb/inch at idle.... is this reading correct. or it is leaking somewhere to cause the intake not getting enough air?
I had a p300-4 code at idle once after I changed the battery this afternoon.
