Is there any rear brake upgrade kit for Porsche 928?
I want monoblock calipers.
Standard brake rotors on my car is now 951-352-041-91 and calipers 92835242103 and 92835242203.
I am a wear of that i need some brackets to make monoblock calipers to fit.
Is it any one here who has did a upgrade i reqest here????
\Bruno,
You can upgrade the rear braking on a 928 by changing the bias valve ( it is on the left fender inside the engine compartment, a round cylinder in the brake line about where the PS fluid reservoir is). Most come OE with an 18 bar valve. 33 bar, 45 bar and 55 bar are available. 45 bar is out of production, but you might be able to find one. 33's and 55's are readily available from 928 International and 928 Specialists (www.928intl.com, and www.928gt.com respectively in the US, or Porsche dealers, obviously).
Gary Knox
Edited by Gary Knox
