My car is a 2004 GT3 and I've noticed a behavior with the fans and coolant temperature that I thought unusual. On the track, driving hard, on a hot day (over 85 deg F) the coolant never goes over 180 deg F. On the road, again on a hot day, in slow traffic, I have seen the needle move somewhat above 180 deg F. The factory shop manual wiring shows (for the regular 996) two fans, each with 2 speeds (full speed-no resistor, and slow speed-ballast resistor). Control is via 4 relays (positions 19, 20, 21, and 22 in the relay bracket): one each for left side-slow, right side-slow, left-fast, and right-fast. There are 2 fuses, one for each fan. What I found with my car is there is no relay in 19 or 20. When I short relay 21 (fan 2-stage 1) pins 30 to 87 nothing happens. This means either both ballast resistors are out on my car or there aren't any connections to them. When I short relay 22 (fan 2-stage 2) pins 30 to 87 both fans come on (and I'm pretty sure they are on high speed). I'm guessing my car is a normal GT3; it has never had any work done to it. But I cannot find any documentation to support my findings. I conclude also that in slow traffic the temperature must rise more than I've observed before the fans go on at full speed. Updated on 27mar08: as Rob in VA and Pilot_951S correctly pointed out on Rennlist, the GT3 has only one fan, on the right side.
Edited by plima
Hi plima..... Yes, the GT3 Mk II has just one radiator fan.....but, it's on the left side.
