I have a UK spec 2004 996 C4S fitted with a PCM (3.0 version).
If for any reason I disconnect the Battery, will I then need to enter codes (Radio and Nav codes) into my PCM?
When I bought this used car recently I was not give any codes. Should I have been?
I'm confused, because I have researched this question on various forums, but see conflicting answers. :unsure: i.e. My unit never needs recoding because it has an internal memory that always retains them! Or, I should have/need both a Code Card PCM and and Code Card Navigation! Which I don't have, and it will cost me a fortune to get them, and a Porsche dealer can only suppply the Radio code not the Navigation code!
PCM 2 ( U.K. 2004 ) needs no codes, the system is linked to the VIN.
