I got a P1126/1124 (all cylinders beyond lean threshold) on my '99 996.
I gave the MAF a squirt of cleaner and now I also have Pre-DTCs (150/130 and 102) -- Intercore Short on O2 sensors (both banks) and MAF below limit.
Sounds serious, both O2 and MAF? Any ideas?
P0102 Mass Air Flow Sensor - Below Lower Limit
P0130 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Intercore Short Circuit or Limited Voltage Increase
P0150 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Intercore Short Circuit or Limited Voltage Increase
What kind of cleaner did you use?
It looks like you may have contaminated the O2 sensors.
I would buy a new MAF and then reset the codes and see what you have.
I just used the MAF Cleaner from Kragen.. Sprayed, let it dry (evaporate) and reinstall..
Wait.. I also put in some Fuel Injector cleaner. Nothing special, but the techron stuff.
